Guys,
I am trying to add TM1 as a data source in Cognos 10. I have my configuration fully up and running with an SQL 2005 database set as my content DB. (Connection tested in Config manager and all that.)
As you might be able to tell from previous posts that I have tried to change the java home but I have hit issues.
Any ideas what I can try next?
Error Message QE-DEF-0368
- jim wood
- Version: PA 2.0.7
Shop at Amazon
Shop at Amazon
Re: Error Message QE-DEF-0368
This?
https://www-304.ibm.com/support/docview ... wg21343702
If that doesn't work, are you mixing the bitness of Java (32 vs 64)?
Is this a demo or training machine you are trying to build? If you need TM1 Contributor with BI on the same machine, you might be able to hack the JAVA_HOME side of Apache (or Cognos). I did one install like this where I had multiple Javas (Cognos and Apache). I overrode one of the JAVA_HOME searches to force it to the alternate location, but I don't remember which one.
- jim wood
- Version: PA 2.0.7
Thanks for the pointer. I've checked the software version and they are all 32-bit as I'm only running a 32-bit virtual machine as a demo box.
I'm going to have a look at the Tomcat side of things (the one used for contributor) as I have found some instructions on how to override the JAVA_HOME setting,
Shop at Amazon
Shop at Amazon
- jim wood
- Version: PA 2.0.7
I've looked at this long and hard. I decided to create another virtual machine and try things on there. No contributor running or anything else that could cause problems. To my surprise I hit the exact same error. I decided it was time to hit the books. I went through the installation documentation. In both my instances I was connecting to SQL 2005. When going through the documentation I noticed a section on creating a user, database and schema. I followed this and changed the settings in configuration manager. Low and behold it worked. I can only come to the conclusion that although configuration manager likes connections using a Sysadmin account the software itself doesn't.
At least I found the problem,
Shop at Amazon
Shop at Amazon
