I am currently in the process of replacing rules-calculated cells with hard values: I export the data, 'stet' out the rules and import data again. Not a big deal
This happens for the years 2005, 2006, 2007, 2008, 2009 in the Years dimension. For the years 2010, 2011, 2012, ... the rules should still apply.
For rules, this is straightforward. For feeders though, will I need to limit the left-hand side of the feeders to the years after 2009?
The idea is that 2005-2009 is populated with hard values, but there can still be feeders associated to these cells. But the feeders serve no purpose anymore since there are no rules active for 2005-2009.
Would it be wise and useful to insert {'2010','2011','2012'} in the left hand side of all the feeders? Or will there be no effect on cube size and memory usage if I do not add them?
Thanks for your insight,
Wim
