process to list out the dimensions
guntupalli
OLAP Product: tm1
Post by guntupalli »
experts,
i have more than 100 processes in TI , Does anyone know a process to list out which process is creating corrosponding dimension.
Thank and Regards
Best Regards,
Guntupalli
Re: process to list out the dimensions
I'm afraid your question does not make sense, "profiles" is not a piece of TM1 terminology and don't really understand how this relates to creating a dimension.
Perhaps you could rephrase your quesiont?
qml
Excel Version: 2007 - 2016
Post by qml »
Guntupalli, I can see you've edited your original post after Steve's reply and changed "profiles" to "processes". This is probably not the best way of clarifying what you meant as it makes the thread disconnected and hard to follow for other users.
The answer to your question is:
You have to make the effort and go through the code of all these processes to know which ones are written to amend any dimensions. You can however quite easily automate this by creating a TI process (or a script using any other language, like Perl) to scan through all your *.pro files looking for specific syntax (e.g. DimensionElementInsert).
That is unless your requirement is to know which processes have actually been executed to amend any dimensions - in this case your best option is is to prepare a tracking cube and update your processes by adding code snippets to each one to record any actually performed dimension changes in that cube (possibly with date and user id etc).
Kamil Arendt
guntupalli
OLAP Product: tm1
Sorry for not informing about the edit("profiles" to "processes").
in my case second option is well suited.
Thanks for your answer.
Best Regards,
Guntupalli
csjean
Version: 9.5 9.5.1 9.5.2
Post by csjean »
guntupalli wrote:Sorry for not informing about the edit("profiles" to "processes").
Hi Guntupalli,
You can even use your perl process to generate a file that is compatible with the DOT graphical engine (http://www.graphviz.org)
This way, you get a nice picture of what TI populate what dimension (or even what cube).
Cheers!
Cheers!
Claude-Sebastien Jean
Senior Consultant in Information Technology
Keyrus Canada
www.keyrus.ca
Martin Ryan
Post by Martin Ryan »
You could use the TM1 Tools add-in to achieve this. It has a function that provides the ability to load text files (including .pro and .rux files) into an excel workbook and then search them for a specified text expression. This can help determine the TI processes or rules which affect a specified cube or dimension.
Jodi Ryan Family Lawyer
