Chore failed
ravi
OLAP Product: cognos
Version: tm1 9.5
Chore failed
Post by ravi »
One of the chore in our tm1 model failded.
View Message log Error: says
“Dimension Update – Project”. one of the project code xxxx is locked
where can i- debug this issue- pls advise.
ravi
Re: Chore failed
Presumably someone has locked the element .... This means no data updates can be made against the element in any cube, nor can it be deleted or moved in the dimension strucure.
Provided you have admin rights then in subset editor right-click the element in question and select security > unlock.
ravi
Version: tm1 9.5
Re: Chore failed
Post by ravi »
Hi lotsaram,
Thanks- it worked.
ravi
