When I use DayNo function to convert a date (e.g. YYYY-MM-DD) to a number to store in a measure. When formatting the measure to view the date in the cube viewer (DD-MM-YYYY), I do not get back the same date.
This is not consistent or coherent at all.
Is this a bug, or am I missing something? I'm using TM1 9.5.1.
Thanks.
Melvin
Bug with Dates in TM1
melvinleng
- Version: 9.5.2
Re: Bug with Dates in TM1
My recollection is that dayno uses TM1's 'Day zero' of 31/12/1959, but the formats use Excel's Day zero of 31/12/1899, so you need to offset by the difference of 21916. Not sensible I know, but perfectly manageable.
John Hammond
- OLAP Product: PAW/PAX 2.0.72 Perspectives
- Version: TM1 Server 11.8.003
- Excel Version: 365 and 2016
He must have had a very good reason to chose a base date not compatible with the world most used business software.
31/12/1959 is Val Kilmer's birthdate so mebbe the TM1 founder liked that film, Top Secret, a lot.
David has probably pointed you in the right direction; I suggest reading this post if you want further clarification on that.melvinleng wrote:Hi all,
melvinleng
- Version: 9.5.2
Thanks guys.
I guessed so. Just want to confirm this is the correct behavior. (Confusing though, when having a mix of formatting and using rules)
Melvin
Melvin
Via Stephen Waters, via an IBM gathering last week, the suggestion is that it relates to the Cuban Revolution. Yes, I know TM1 uses 31/12/59 and Castro rolled in on 1/1/59. I think Manny has more important things to sort out than this
http://en.wikipedia.org/wiki/Cuban_Revolution
- Carolyn
- Version: 10.1
I'm doing exactly that and it works great.David Usherwood wrote:My recollection is that dayno uses TM1's 'Day zero' of 31/12/1959, but the formats use Excel's Day zero of 31/12/1899, so you need to offset by the difference of 21916. Not sensible I know, but perfectly manageable.
