Server Explorer Bug: One User Affected Only
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
In 7+ years of using TM1 i have never come across an issue like this. I'm finding it hard to understand why it happens and as a result impossible to cure.
The issue is a slightly corrupted server explorer, specifically the application folders. Below are a before & after screen shot;
Before Corruption
Before Corruption
TM1 App Folder Before.jpg (24.92 KiB) Viewed 2939 times
After Corruption
After Corruption
TM1 App Folder After.jpg (25.29 KiB) Viewed 2939 times
On first logging in, the user's screen looks fine. Each icon correctly represents the item it is linked to.
On clicking the parent folder, the list is changed. The icons no longer match and as a result clicking on the items does nothing. User can not even right click an item and in some cases it states the item has gone and do you want to delete it.
It is not linked to the user's TM1 account. They can log on to TM1 via my machine and it works as it should.
It is not linked to the folders themselves as only one user has been affected.
It is not linked to their PC because i can log on and it works as it should.
If they log on to another PC they get the same issue.
By that elimination it must either be a windows security issue or a windows profile issue on this one user. IT have attempted to reset the profile but i'm not convinced that was done as fully as it could. My question is has anyone seen behaviour like this before or know what causes it / how to fix it?
stephen waters
Version: 10_2_2
Excel Version: Excel 2010
Re: Server Explorer Bug: One User Affected Only
Post by stephen waters »
Steve
Display corruption can happen if there is a problem with the TM1P.Ini file which is user specific. Try deleting\removing the TM1p.ini in that user's documents and settings folder (\application data\applix\tm1) and see if that helps.
btw, nice to see that Applix name survives somewhere!
Martin Ryan
Post by Martin Ryan »
Looks fairly similar to an issue I had a while ago: http://www.tm1forum.com/viewtopic.php?p=19988?
Jodi Ryan Family Lawyer
Steve Vincent
Version: 10.2.2 FP1
Cheers. Have tried removing the TM1P.INI to no effect. The "it depends how you click it" fix is proper odd! Have tried that also but no, it does the same either way. It only affects folders that have word documents linked but i'm still no closer to figuring out a reason why. Could anything like .NET cause stuff like this?
