I want to use Excel file as source for downloading into TM1 data and dimensions.
So I create Excel file - with name Departments.xlsx. Create sheet Department in it. Then fill column A as
1 Departments
2 Department1
3 Department2
4 Department3
Then I create ODBC source Departments which look on file Departments.xlsx
Then I create TI process. DataSource Type is ODBC. In Data Source name chose ODBC source departments and tried to write SQL statement
I tried
select [Departments] from [Departments];
select [A] from [Departments];
select * from [Departments];
The result is one:
SQL statement failed
Can somebody say that I should write in query?
Using Excel as ODBC - can't write sql
- OLAP Product: PAL
- Version: 2.0.9
Re: Using Excel as ODBC - can't write sql
You need to specify the sheet, as you have already specified the workbook in the ODBC setup.
You also need to add an $ at the end so try:
Select * from [Department$];
I have never used this on a live system - usually trying to get away from Excel datasources.
Tom
Tom
- OLAP Product: PAL
- Version: 2.0.9
Thank you a lot
Select * from [Department$]; helped
