We are facing the problem with the consolidation .
Problem is :
+Total 80
Value1 10
Value2 20
Value3 30
Valu4 40
The above example the total value should be 100 but it is skipping value 2 .
All the childs are rule calculated values . PLease provide me some ideas .
Ashok
Consolidation Issue
Acc_Moonwalk
- Version: 9.4
- Excel Version: 2003
Acc_Moonwalk
- Version: 9.4
Re: Consolidation Issue
Weight for all the Childs is "1".
Ashok
Ashok
- Michel Zijlema
- OLAP Product: TM1, PALO
Hi Ashok,Acc_Moonwalk wrote:We are facing the problem with the consolidation .
Problem is :
+Total 80
Value1 10
Value2 20
Value3 30
Valu4 40
This looks like a feeder problem - if you do a 'Check Feeders' on the total element the message will probably say 'not fed' for Value2.
Michel
