I'm currently developing a 5 year planning tool, and being fairly new to TM1 i could do with some advice on the following point.
I read on a forum page that there is a dataspread function which allows you write back to consolidated cells, the data is then relatively proportionally spread over the cells descendants. An extract from the forum is shown below. Is this functionality available in TM1 v9.5.1?? Or i have i completely misunderstood the function
Extract....
"Retrieves Numeric data from a Keystone Cube at an Intersection of Elements. The number of parameters this function has matches the number of Dimensions in the Specified cube plus one for the cube itself. This function is also write-back enabled meaning that when data is entered over this formula and the formula references a writable cell within the cube that data is sent into the cube and the forumla is left in tact.
Parameters:
1: Cube Name
2,3,4...N: Elements from the Cubes Dimensions (in Order).
Example:
=dataspread("Sales","Gross Sales $","2010","Jan","Field Sales","1002 - DynaRub 100ml")"
Many thanks
Lee
