Hi friends,
I need to do some calculation based on multiple condition. Please tell me how to check or use multiple condition in single If.
How to check multiple condition using single if In TM1
- Martin Ryan
- Version: 10.1
Re: How to check multiple condition using single if In TM1
Do you mean in rules or in TI?
If in rules:
['left'] = N:
if(x=y, ['1'], if(z=q, ['2'], if(a=b, ['3'])));
If in TI:
if(a=b);
do something;
elseif(c=d);
do something else;
elseif(e=f);
something else;
else;
catch all other cases;
endif;
If in rules:
['left'] = N:
If in TI:
if(a=b);
do something;
elseif(c=d);
do something else;
elseif(e=f);
something else;
else;
endif;
Jodi Ryan Family Lawyer
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
If you want to combine them into a single statement then & is AND, % is OR, ~ is NOT.
So in TI
in a rule
So in TI
If( (a<5) & (b>10) );
do true stuff;
Else;
do false stuff;
EndIf;Code: Select all
['Result'] = N:
If( (['Test 1'] > 0) % ~(['Test 2'] < 0) ),
['TrueValue'],
['FalseValue']);Andy Key
k2g
- Version: 9.5
Thanks for your answer,
I want to implement any one of OR, AND, NOT in if using TI process.
k2g
- Version: 9.5
Can i write in TI like
IF((var1=5) % ( var1=6) % (var1=7));
to check that value of var1 is 5 or 6 or 7(i.e. using OR condiotion)?
Yes.
Remember you need to use @= for strings.
k2g
- Version: 9.5
Thanks David:)
