ASCIIOutput a tab delimited file
Fionnuala
Version: 9.4.1 FP3 HF4 and 10.2
Excel Version: 2007 and 2010
Post by Fionnuala »
I'm using ASCIIOutput to create a file but need it to be a tab delimited type.
Does anyone know if it's possible to specifiy this in TI?
Thanks for your help,
Fionnuala
jim wood
Version: PA 2.0.7
Re: ASCIIOutput a tab delimited file
Post by jim wood »
It is comma delimited only as far as I am aware. You could write a btach file that opens the file and replaces commas with tabs. You could run the batch within TI after the ASCIIOuput has finished,
Fionnuala
Post by Fionnuala »
Thanks Jim, I'll try that.
It certainly seems like there's no option in TI so a batch file might do the trick.
Fionnuala
BTW I'm using 9.4FP3
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
You can use the DatasourceASCIIDelimiter TI variable to specify the field separator.
F.i.: DatasourceASCIIDelimiter=Char(code);
where code is the ascii code for tab.
Michel
Fionnuala
Post by Fionnuala »
Thanks very much Michel, that seems to have worked with the code 9 for tab..
I just need to get rid of the "" around each field now,
Fionnuala
Fionnuala
Post by Fionnuala »
ok I have it with
DatasourceASCIIDelimiter=Char(9);
DatasourceASCIIQuoteCharacter='';
Fionnuala
Michel Zijlema
Fionnuala wrote:Thanks very much Michel, that seems to have worked with the code 9 for tab..
You can use the DatasourceASCIIQuoteCharacter variable for that:
Michel
Edit - Ok, you already found that ;)
