[SOLVED] "Measurement unit" member consolidation problem
abcuser
Version: 9.5.2
Excel Version: 0
Post by abcuser »
using TM1 v9.5 on Windows I have four dimensions:
- measure (value and quantity members),
- measurement unit (kg, ton, m, m2, piece members),
- buyer and
- product.
I have a consolidation problem at top member "Measurement unit". "Measurement unit" member should be consolidated according to measure member. If measure is Value then "Measurement unit" should be sum of children of "Measurement unit". If measure is Quantity then "Measurement unit" should have no value (probably zero).
How to write a rule for "Measurement unit" member?
P.S. To simplify sample I have omitted buyer and product dimension in attached picture.
abcuser
Version: 9.5.2
Excel Version: 0
Re: "Measurement unit" member consolidation problem
Post by abcuser »
I have found out solution. In cube's rules I have written:
SKIPCHECK;
['Measurement unit','Quantity']=0;
Thanks, problem solved.
