Has anyone got an example I can have a look at.
I can connect to the cube and get dimensions back but completely at a loss on how to use the hierarchy class.
The API documentation does not make it particularly clear.
Further is there any Java code around that can help show how to use the TM1 API. I have googled all over the net and there is very little. Only looking to read from the cube, do not want to write to it.
TM1Hierarchy Java Example Wanted
csjean
- Version: 9.5 9.5.1 9.5.2
Re: TM1Hierarchy Java Example Wanted
Hi,TM1Newbie wrote: Further is there any Java code around that can help show how to use the TM1 API. I have googled all over the net and there is very little. Only looking to read from the cube, do not want to write to it.
There is very little code "floating" around.
There are some [small] classes example in :
<tm1 install dir>\API\TM1API\SampleCode\java
Besides that, I gess you'll have to do it the old fashionned way: trial and error.
Hope this helps.
Cheers!
Claude-Sebastien Jean
Senior Consultant in Information Technology
Keyrus Canada
www.keyrus.ca
Keyrus Canada
www.keyrus.ca
image2x
- OLAP Product: TM1, PAX, PAW, SPSS
- Version: 2.0.916.10 on RHEL
This is the most comprehensive java api source code example I've come across:
http://ykud.com/blog/cognos/tm1-cognos/ ... tm1-models
csjean
image2x wrote:This is most comprehensive java api source code example I've come across:
Cool! It looks like a very promising tool.
Thanks.
Cheers!
Keyrus Canada
www.keyrus.ca
Keyrus Canada
www.keyrus.ca
