I'm having an issue with TM1 security, after upgrading from 8.X to CX 9.5.
After successfully installing the server, installing the Xcelerator client on a new machine works fine.
However, when I install the Xcelerator client on a machine that has previously had the old add-in installed, when logging in as an Admin, I cannot edit chores, TI processes, change security etc.
Even after uninstalling the Xcelerator client and deleting ALL old Applix folders and files (i.e. C:\Applix\ and AppData), the issue remains. I have been told by the client that they did not install the old client on their machines, merely copied folders across.
Even if I copy the bin directory containing the same tm1p8.lic file from the working machine, I do not get admin access.
One thing I notice is that the tm1p.ini file is created in the C:\Applix folder as opposed to the AppData folder on the fresh machine.
I am using native TM1 security, and have tried adding a new client and adding to the Admin group, and get the same issue.
Any help would be greatly appreciated.
Dan
Upgrade Issue TM1 8.X to Cognos Express 9.5
dan.kelleher
- Version: 9.4
- Excel Version: 11
Re: Upgrade Issue TM1 8.X to Cognos Express 9.5
I don't use CX, but the symptoms sound exactly like a missing Perspectives license file rather than any issue with security as such. Take a look at this thread and see whether putting the tm1p8.lic licence file into the specified directory works for you.dan.kelleher wrote:I'm having an issue with TM1 security, after upgrading from 8.X to CX 9.5.
