We have a cube that has two cub files
one with .cub$ and the other with .cub
Any ideas on what this is? Also, we appear to have data loss issues during server restarts. I ran a relative proportional spread during the day for a user at some point and after restart the spread was no longer there. I did a SaveDataAll before the restart as well.
$ appended to .cub file
PlanningDev
- Version: 2.0.5
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Re: $ appended to .cub file
Make a search for cu$ on this forum and will find answer for your questions.
HTH
HTH
Best Regards,
Peter
Peter
PlanningDev
- Version: 2.0.5
I tried searching before I posted and using what you said and I get no matches found.
Is there a specific string that I should use?
Yes, unfortunately that one can be a bit tricky to search on because of the minimum character limitation in the search engine. This thread should tell you what you need:PlanningDev wrote:I tried searching before I posted and using what you said and I get no matches found.
http://forums.olapforums.com/viewtopic.php?f=3&p=5791
I'll add that one to the FAQ as it comes up a lot.
