I would like to extract all the children of a roll-up. I know there is no loop in a TI.
Does anyone know of an alternative?
TI to extract all children ?
Re: TI to extract all children ?
What do you mean "there is no loop in a TI"?telula_w wrote:I would like to extract all the children of a roll-up. I know there is no loop in a TI.
You use a While loop. You get the number of children with ElCompN and use a While loop to get the ElComp values from 1 to the ElCompN value.
Or...
Just set your data source to be all elements of the dimension, then test using ELISANC.
I think you mean either ElIsComp or ElIsPar, depending which way around you do the test. Of course this presupposes that the question really is what it says it is; that is, wanting "children" rather than "descendants".David Usherwood wrote:Or...
