F9 versus Application.Calculate
image2x
OLAP Product: TM1, PAX, PAW, SPSS
Version: 2.0.916.10 on RHEL
Post by image2x »
I'm seeing a marked performance difference (10x) between a refresh perfomed with a manaul F9 keystroke compared with executing an Application.Calculate in VB. This is on a worksheet with ~20k dbrw statements. The F9 method is faster.
Does TM1 "intercept" F9 when entered manually and process differently? If so, can one call the TM1 refresh directly from VB?
-- John
Paul Segal
Version: TM1 11 and up
Re: F9 versus Application.Calculate
Post by Paul Segal »
Yes. Record a macro with F9 as the only keystroke, and you will see the code TM1 uses in the recorded macro. It does differ by version.
Paul
afshin
Version: 9.5
Post by afshin »
Yes TM1 will interpret F9 when entered manually you could also use the SendKeys "{F9}" .
