Need help with feeder
telula
Post by telula »
I want to put a flag=1 for the following accounts and companies.
What feeder should I put ?
['Flag']=N:IF(ELISANC('account','X000000',!account)<>0,IF(ELISANC('company','AUS',!company)<>0,1,0),0);
Thanking you in advance
Martin Ryan
Re: Need help with feeder
Post by Martin Ryan »
You can't write a feeder for that without seriously overfeeding. I'd suggest one of two different approaches.
1) Create an attribute called Flag against both of the dimensions and either populate the data manually, or write a rule in the attributes cube without skipcheck of feeders.
2) Don't have a Flag field. Instead use the if statements you've written below but nest them in the calculation that you were intending to use the Flag field for.
Personally I'd go with 1.
Martin
Jodi Ryan Family Lawyer
