Greetings:
I'm writing a Turbo Integrator process and need to multiply by the weight of the parent of an element. For example, I have an account 14600 - C02. It's parent is 14600 and has a weight of -1. When I come across account 14600 - C02, I need to look up the weight of the parent. Any way of doing that?
Tubo Integrator function to return weight?
Re: Tubo Integrator function to return weight?
Rule functions can be used in a TI process too. Look in the help file for the rule functions for dimensions and elements and I'm sure you'll find what you are looking for. Keep in mind you can nest functions if need be.
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
You can use the rule functions in TI:ChrisF79 wrote:Greetings:
ELWEIGHT(dimension, element1, element2)
dimension A valid dimension name.
element1 The name of a consolidated element within the dimension.
element2 The name of a child of the consolidated element.
HTH
Best Regards,
Peter
Peter
ChrisF79
- OLAP Product: IBM TM1
- Version: 9.5.1
- Excel Version: 2007 SP2
That'll do it. Thank you!kpk wrote:You can use the rule functions in TI:ChrisF79 wrote:Greetings:
HTH
