A new feature in 9.5.1 is client side logging
Here is an example on how to set it
Tm1p-log.properties files example:
• It can be only set to OFF or DEBUG
• these parameters will only work with 9.5.1>
• place Tm1p-log.properties under C:\Documents and Settings\<user name>\Application Data\Applix\TM1 (%APPDATA%\Applix\TM1) on client system NOTE: tm1p.ini must be in same folder
• Logging output needs to be set by either of these 2 methods
log4j.appender.R1.File=c:\\ClientLog.log
or
log4j.appender.R1.File=c:/temp/ClientLog.log (notice the slash)
log4j.rootLogger=, R1
#Server Explore
log4j.logger.COrionMainApp=DEBUG
log4j.logger.CCubeView=DEBUG
log4j.logger.CubeViewGrid=DEBUG
log4j.logger.COrionTreeView=
log4j.logger.COrionApp=
log4j.logger.CMultiSelect=
log4j.logger.CCreateSandbox=
log4j.logger.loggerViewDimension=
#Subset Editor
log4j.logger.CSubsetWnd=DEBUG
log4j.logger.CSubsetEntry=DEBUG
log4j.logger.CSubsetListProp=
log4j.logger.CSubsetListBox2=
log4j.logger.CSubsetListView1=
log4j.logger.CSubsetRegExp=
log4j.logger.CSubsetSelByAttr=
log4j.logger.CSingleSelect=
#ISB
log4j.logger.CXLCtrlsApp=
log4j.logger.CConnectServerDlg=
log4j.logger.CViewCtrl=
log4j.logger.CGetViewDlg=
log4j.logger.CubeViewerISB=
log4j.logger.ExcelReportPrintDPage=
log4j.logger.CTM1Connector=
log4j.logger.ExcelReportPrintIncludedSheetsPage=
log4j.logger.CAutoExcel=
log4j.logger.SubsetEditorIntLog=
#Perspectives
log4j.logger.TM1Perspectives=DEBUG
log4j.logger.TM1AF=
log4j.logger.TM1ExcelAPI=
log4j.appender.R1=org.apache.log4j.RollingFileAppender
#log4j.appender.R1.File=c:\\ClientLog.log
log4j.appender.R1.MaxFileSize=10 MB
log4j.appender.R1.MaxBackupIndex=50
log4j.appender.R1.layout=org.apache.log4j.PatternLayout
log4j.appender.R1.layout.ConversionPattern=%X{pid} %t %p %d{%Y-%m-%d %H:%M:%S,%Q} %c %m%n
log4j.appender.R1.layout.TimeZone=GMT
Client-side logging -- 9.5.1
Re: Client-side logging -- 9.5.1
is this for keeping track of changes made to sandbox data or private subsets?
- Version: 9.5
- Excel Version: 2003
I believe it is for debugging issues in the client. This is akin to the server side logging.
