hi
1)is it possible to create cubes in excel
2 )how to create cube for data directory?
creating cubes in excel?
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Re: creating cubes in excel?
1. You can create cube with TI. You can use action button to run TI process from Excel or from websheet.
2. I do not understand the second question.
Best Regards,
Peter
Peter
KRISHNA
- OLAP Product: cognos tm1
- Version: 9.4.1
hi,kpk wrote:1. You can create cube with TI. You can use action button to run TI process from Excel or from websheet.
directly cant we create cube in excel? and
my 2nd question is "i need to create cube for data directory"of TM1 server ,is it possible ?
kpk
There is no Excel solution for creating cubes in Excel like XDI for dimensions or XRU for rules.KRISHNA wrote:hi,kpk wrote:1. You can create cube with TI. You can use action button to run TI process from Excel or from websheet.
Best Regards,
Peter
Peter
KRISHNA
- Version: 9.4.1
thanks q kpk.
Not sure I understand the question either as what exactly is meant by "creating cubes in Excel"?
With administrator privileges this can be done quite easily in Perspectives server explorer (the TM1 add-in for Excel). Just right-click "cubes" and select "create new cube". In my definition this would qualify as "creating a TM1 cube in Excel."
