after looking for an error I found out, that the timestamp in the log files differs from Windows Server time by two hours.
I'm in the time zone "UTC+1h". Any idea what time zone TM1 has by default and how can I change it?
Kind regards
Steve
DifferentTimes between server and TM1
Re: DifferentTimes between server and TM1
By default TM1 logs everything in GMT.
It is a little known fact that this doesn't have to be the case. Just edit the tm1s-log.properties file in notepad and change the time stamp property from "GMT" to "Local" and restart the server and TM1 will then log in local server time. (However only do this if you are not replicating servers across time zones!)
- Martin Ryan
- Version: 10.1
Good tip - I'll move this into the tips and tricks forum soon.
However, I haven't been able to get it to work yet - where should this file reside? In the Data directory? Logging directory? I've tried both with no success - example file below.
Does it just alter the tm1s.log file, or the tm1server.log file as well?
# Enable INFO level logging through the shared memory appender, by default. The server # will write informational messages, as well as errors and warnings to the log file.
log4j.logger.TM1=INFO, S1
# S1 is set to be a SharedMemoryAppender
log4j.appender.S1=org.apache.log4j.SharedMemoryAppender
# Specify the size of the shared memory segment
log4j.appender.S1.MemorySize=5 MB
# Specify the max filesize
log4j.appender.S1.MaxFileSize=100 MB
# Specify the max backup index
log4j.appender.S1.MaxBackupIndex=20
# Specify GMT or Local timezone
log4j.appender.S1.TimeZone=Local
Jodi Ryan Family Lawyer
There isn't much to it just change
log4j.appender.S1.TimeZone=GMT
to
The tm1s-log1.properties file needs to be in the same location as the tm1s.cfg file, so more than likely the data directory. Changing the log mode and file size options have immediate effect but changing the timezone requires a server restart to take effect. I haven't ever had any problems with getting this to work.
to
You're showing your version as 9.1; I believe that this was introduced in 9.4.Martin Ryan wrote:Good tip - I'll move this into the tips and tricks forum soon.
# # Enable INFO level logging through the shared memory appender, by default. The server # will write informational messages, as well as errors and warnings to the log file. # log4j.logger.TM1=INFO, S1 # S1 is set to be a SharedMemoryAppender log4j.appender.S1=org.apache.log4j.SharedMemoryAppender # Specify the size of the shared memory segment log4j.appender.S1.MemorySize=5 MB # Specify the max filesize log4j.appender.S1.MaxFileSize=100 MB # Specify the max backup index log4j.appender.S1.MaxBackupIndex=20 # Specify GMT or Local timezone log4j.appender.S1.TimeZone=Local
SBrenner
- Version: 9.5.0
Thanks for the hint. It works as described.
- Martin Ryan
- Version: 10.1
That was my problem. I generally have my cfg file in the parent directory above Data and Logs subdirectories.lotsaram wrote: The tm1s-log1.properties file needs to be in the same location as the tm1s.cfg file.
Thanks for the tip lotsa.
Martin
nataraja.pl@tcs.com
- Version: 9.4
Thank you so much lotsaram & Alan,It working fine. I am eagerly searching for the same.
Nata
Nata
