ExecuteCommand Function in TI Unable to Run Batch File
kali
Version: 9.4.1
Post by kali »
I am trying to execute a batch file in TI using the “ExecuteCommand” function.
ExecuteCommand('RenameFile.bat',0);
When I run the batch file manually it works fine.
The problem is when I run the batch file using the “ExecuteCommand” function. The TI process returns a “Process completed successfully” message, but it doesn’t do anything.
I know that the function can access the file, because it returns an error whenever I change the file name that I pass in.
I am using an administrator account to logon to Architect and the TM1 services are running as “Local System Account”.
I have also tried to allow “Full Control” privilege to the batch file, but this did not fix the issue.
Does anyone know why this is happening?
Thanks!
jrizk
OLAP Product: Tm1
Re: ExecuteCommand Function in TI Unable to Run Batch File
Post by jrizk »
Maybe the file your are trying to rename is locked when the ExecuteCommand is being run - the TI process would still return “Process completed successfully”.
J.Rizk
Tm1 for everyone
If you want to run a batch file from a TI process you have to open a command window (with a parameter set to automatically close the window upon completion) first and then run the batch file. It would look something like this:
CommandLine ='cmd /c RenameFile.bat';
ExecuteCommand(CommandLine, 0);
