What script i need to write to export the cube view to Excel or CSV and this process should be added in chores. And where to write??.....
Thanks for your time.
Export Cube ViewTo Excel/CSV
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
- rkaif
- Version: 9.1 or later
Re: Export Cube ViewTo Excel/CSV
You can use ASCIIOutput() function to export data to CSV file
Crate a TI Process
Data Source tab: Use the Cube View as the Data Source
Variable tab: declare all the variables as Other
Advanced -> Data tab: use ASCIIOutput function to export the data to CSV file
Hope that helps!
Crate a TI Process
Hope that helps!
Cheers!
Rizwan Kaif
Rizwan Kaif
- vinnusea
- Version: 10.2
ASCIIOUTPUT('C:\Documents and Settings\preeth\Desktop\TEST11.cma', v1, v2, v3, v4, v5, v6 );
I took TM1 Cube view as source and all variables to Other and gone to Data taba and wrote above code and its throwing me error
syntax error on or before :
v6 );
invaled string expression"
Can you help me ...plz
v6 );
Vinnusea
Vinnusea
ASCIIOutPut command can only output text, You'll have to convert v6 to text before you can use it in the formula.
aryan
- OLAP Product: oracle
- Excel Version: 2013
When I am Converting Number to string Only one value is converting and i am getting only one value in the output how to change total data to string
Read the request for assistance guidelines first and then come back with the kind of information you need to be providing. I have no clue what you are talking about.
- Steve Rowe
Hmmm, you need to convert each field/column/variable to a string independently, so if you have 5 numeric variables then you'll need to write.
AsciiOutput( 'WhyIsThisFunctionNameSoLong.cma' , NumberToString( v1) , NumberToString( v2) , NumberToString( v3) , NumberToString( v4) , NumberToString( v5) );
If that doesn't answer your question then I'm not sure what you are after either..
