I have Values in the Cube view which are -ve and some are +ve.
But when i click Suppress zero button everyting is going and showing "no values"
Can any 1 tell me what will be the reason?.
Zero Suppression_suppress My Values
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
- rkaif
- Version: 9.1 or later
Re: Zero Suppression_suppress My Values
Are you in the Cube viewer?
Suppressing Zeros only hide the cells which have zeros in them. If you have +ve or -ve number then they should not be suppressed. Unless you are changing the selection from the Title dimension in the cube viewer????
Elaborate what you are doing or post the screen shots.
Cheers!
Rizwan Kaif
Rizwan Kaif
What about rules and feeders on the cube at which you are looking? Are they appropriate?
