Every Monday, a file is extracted from a source system. The file contains an inception-to-date (from 1996) count of product purchases
File of : Monday 2/2/2010
Date Product Count
2/2/2010 prod1 10
2/2/2010 prod1 15
2/2/2010 prod1 18
2/2/2010 prod1 21
File of : Monday 2/8/2010
2/8/2010 prod1 15
2/8/2010 prod1 20
2/8/2010 prod1 23
2/8/2010 prod1 26
Inception to date values are pulled because adjustments are made to prior weeks in the souce system.
Is it possible to create a Ti process that poplulates two measures: One with the inception-to-date value on the file and a second with the change in count from the previous load.
The n level elements in the Time dimesnion look like this: 201009W1
Walt
Convert Snapshot Closing Blances to Balance Change
- Version: 2.5 to PA
- Excel Version: Lots
Re: Convert Snapshot Closing Blances to Balance Change
If you definitely want to do this within TI (rather than using a hierarchy or rules), then use an attribute that points to the previous week and a CellGetN to read last weeks number then use a CellPutN to write the difference between the CellGetN and the current value to your second measure.
Andy Key
