Combining 2 mdx statements in a string to create subset
gabriele
Post by gabriele »
In TI Process I am trying to combine 2 MDX statements into a string to create the subset and get the error "Invalid String Expression".
I am using generic code to create subsets that are filtered by level zero, and then overriding some subsets because I do not want these at Level zero.
If using a simple MDX statement, it works and creates the subset correctly such as this one:
#OVERRIDE SUBSETS CREATED WITH SPECIFIC ELEMENT VALUES OR MDX STRINGS
#CAPITAL_DEPRECIATION_M
OverrideDim = 'Capital_Depreciation_M';
StringMDX = '{TM1SUBSETALL( [ ' | OverrideDim | ' ] )}';
IF (SubsetExists (OverrideDim, SubsetName) <> 0);
SubsetDestroy (OverrideDim, SubsetName);
SubsetCreatebyMDX (SubsetName, StringMDX);
ELSE;
ENDIF;
When I try to combine 2 MDX statements into a string, I get an error:
#TIME_PERIOD-FORECAST
OverrideDim = 'Time_Period-Forecast';
StringMDX =
IF (vTargetScenario @= 'Test2',
SubsetCreatebyMDX ( OverrideDim, ' {TM1FILTERBYLEVEL ( { DESCENDANTS ( { FILTER ( { TM1SUBSETALL ( [ ' | OverrideDim | ' ] ) } , [ ' | OverrideDim | ' ].[ PlanYear ] = "Y" ) } ) } , 0 ) } ' ) ,
SubsetCreatebyMDX ( OverrideDim, ' { TM1FILTERBYLEVEL ( { DESCENDANTS ( { FILTER ( { TM1SUBSETALL ( [ ' | OverrideDim | ' ] ) } , [ ' | OverrideDim | ' ].[FcstYears] = "Y" ) } ) } , 0 ) } ' ) ) );
SubsetCreatebyMDX (SubsetName,StringMDX);
ELSE;
ENDIF;
It complains that the MDX string is invalid.
Does anyone know how this can be corrected?
Thank you in advance!
Gabriele
Re: Combining 2 mdx statements in a string to create subset
For instance:
IF (vTargetScenario @= 'Test2');
StringMDX =' {TM1FILTERBYLEVEL ( { DESCENDANTS ( { FILTER ( { TM1SUBSETALL ( [ ' | OverrideDim | ' ] ) } , [ ' | OverrideDim | ' ].[ PlanYear ] = "Y" ) } ) } , 0 ) } ';
Else;
StringMDX=' { TM1FILTERBYLEVEL ( { DESCENDANTS ( { FILTER ( { TM1SUBSETALL ( [ ' | OverrideDim | ' ] ) } , [ ' | OverrideDim | ' ].[FcstYears] = "Y" ) } ) } , 0 ) } ';
EndIf;
gabriele
Post by gabriele »
Thanks for the reply.
However, I want to select both attributes IF (vTargetScenario @= 'Test2');:
PlanYear:
and FcstYear:
in one string
and not select PlanYear if (vTargetScenario @= 'Test2');
and select FcstYear if (vTargetScenario does not equal 'Test2');
so the Else statement is only applicable if the subset does not exist, and then have TI process create it.
This may not be possible.
The code works fine when I am not using the looping technique with generic code, such as
If (vTargetSenario @='Plan',
SubsetCreatebyMDX('zzTime_Period','{TM1FILTERBYLEVEL ({DESCENDANTS ({FILTER ({TM1SUBSETALL([Time_Period])},[Time_Period].[PlanYear] = "Y")})}, 0)}'),
SubsetCreatebyMDX('zzTime_Period','{TM1FILTERBYLEVEL ({DESCENDANTS ({FILTER ({TM1SUBSETALL([Time_Period])},[Time_Period].[FcstYear] = "Y")})}, 0)}') );
I may need 2 variables when using generic code with my looping technique, because the error I get is that the StringMDX statement is invalid. I am still trying to figure out how to use a second variable.
Thank you!
Check out the "Union", here:
http://www.bihints.com/book/export/html/68
Also, it might be interesting to use another variable to condense the notation.
Wigi
gabriele
Post by gabriele »
Thank you, I will check this out.
