Using TI to execute a SSIS package
JJ2
Version: 9.5
Post by JJ2 »
Hi Everyone, Is there a way to use TI to execute a SSIS package? Thanks!
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Using TI to execute a SSIS package
Post by rkaif »
I have not tried this personally. But I believe you can execute a SSIS package through the command line by using the DTEXEC.EXE utility.
Then you can use ExecuteCommand() function in the TI Process to run your command. Syntax is:
ExecuteCommand(CommandLine, <Wait time>);
Hope it helps!
Cheers!
Rizwan Kaif
JJ2
Version: 9.5
Post by JJ2 »
Thank you Riswan! I will give this a try.
