Good morning!
I just wanna know, is there a way I can write an MDX in the Expression window via TI? And if there is, can you please mention how. Thanks!
(You are highly appreciated)
bunchukokoy
Look in the Help documents for the TI function SubsetCreatebyMDX.bunchukokoy wrote: I just wanna know, is there a way I can write an MDX in the Expression window via TI? And if there is, can you please mention how. Thanks!
9.5.1 Reference Guide (verbatim) wrote:SubsetCreateByMDX
This is a TM1® TurboIntegrator function, valid only in TurboIntegrator processes.
This function creates a public subset based on a passed MDX expression.
Syntax
SubsetCreatebyMDX(SubName, MDX_Expression);
Argument
Description
SubName
The name you want to assign to the subset.
MDX_Expression
An MDX expression that returns a subset.
Example
SubsetCreatebyMDX('0-level months', '{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [month] )}, 0)}, ASC)} ' );
This example creates a public subset named '0-level months' based on an MDX expression that returns a subset consisting of all 0-level elements in the Month dimension, sorted in ascending alphabetical order.
