hi again!
I wonder why in my TI, this code.., prompts an error even though i already have deleted the cube view which used it.
============ at the bottom part of the Prolog
IF (ViewExists(CubeName, DestinationViewName)=1);
ViewDestroy(CubeName, DestinationViewName);
ENDIF;
============ at the Epilog
IF (SubsetExists(DimVersion, DestinationSubVersion)=1);
SubsetDestroy(DimVersion, DestinationSubVersion);
ENDIF;
the scripts in the Epilog tab still prompts an error message.
Please help anyone.
Thanks!
bunchukokoy
SubsetDestroy prompts error
bunchukokoy
- Version: 10.2.2.x
Re: SubsetDestroy prompts error
What error message do you see in the Message Log, and to what line of code is pointing?
Jeroen Eynikel
- The subset may still be attached to another view. The problem here is that I have never found a way to easily identify such cases. Worst case it is attached to a private view of some user in which case you wouldn't even be able to see it.
=> Make a habit of cleaning any views / subsets used in TI process the moment you don't need them anymore. If possible create and delete them again in the same TI process.
- The view may still exist in memory even if you already deleted it. I have seen this happen in the following circumstances.
1: the view is open in SE.
2: try to do the destroy.
3: realize it fails because it was open
4: close the view
5: delete the view
6: subsets still won't delete. In this case unloading the cube from memory or restarting the service usually resolves the problem.
4: close the view
5: delete the view
bunchukokoy
- Version: 10.2.2.x
Jeroen,
Thanks for the idea. But as I looked at my cubes, you are right, there was still a view which was using the subset.
bunchukokoy
bunchukokoy
