Is it possible to import subset from one cube to another cube- if what are the steps.
Note: I have one one subset in a cube - and I want to import this subset to another cube.
Ravi
Subset importing
Re: Subset importing
A subset is attached to a dimension not a cube. If dimensions are shared between cubes then subsets in the dimension will automatically be available for queries to all cubes of which the dimension is a part of.
Try explaining again what you want to do. With your current explanation one would just be guessing at best.
ravi
- OLAP Product: cognos
- Version: tm1 9.5
Yes- Besically I want to share dimension between the cube.
How would i do that-
Now the cube is already created with one wrong dimension-I want import or share correct dimension which is available in some other cube.
Ravi
Ravi
You can't change the dimensions once you've created a cube. The only thing you can do is (assuming that you want the corrected cube to have the same name) is export the data from the existing cube to a text file, delete the old cube, create the new one with the correct dimensions, and reimport the data.ravi wrote:Hi
Ravi
However this doesn't have anything to do with subsets. As lotsaram said, those go along with the dimensions.
