View in a flat file format
Ajay
Version: 10.2.0, PA 2.0.9
Post by Ajay »
Hi All
I'm trying to mimic a flat file by using a view.
Imagine a cube with two dimesions, one for P&L Account, and one for month.
At the moment when produce a view, and run an extract into *cma for it, I get the following output:
Profit, Jul, 10
Profit, Aug, 20
What i'd like to do is having the following:
Profit, 10, 20
My exisiting TI would know that column two is Jul, and that column three is Aug.
Looking at the help screens it would seem that i could use ViewColumnDimensionSet on the month dimension, but i have tried this without success.
Any help from you all would be very welcome.
Ajay
Catherine
Version: 10.2.2 - PA
Re: View in a flat file format
Post by Catherine »
What I would do is build my export in a TI process:
-Build your datasource view with "total year" element regarding Time dimension
-In data, write two CellGetN formula to get July and August values
-Write an asciioutput formula to export 3 fields: P&L account, July value, August value
paulsimon
Version: PA 2.0.5
Post by paulsimon »
Ajay
If you need to automate this via TI then Catherine's suggestion is good. However, if you just want a simple extract in that format, the easiest way is to configure a View with periods across and then snapshot the view to Excel and save as a CSV file. You can automate that via Macros eg VUSLICE etc.
