Integrated login failed
vfhc2003
Version: 9.4x
Excel Version: Excel 2007
Post by vfhc2003 »
We have an issue with integrated login for users accessing TM1 where users client login is not available in the TM1 cube.
Our TM1 installation (TM1 9.5 64-bit) is installed at HQ - the integrated login works for these users.
For the users outside the domain (stores) they login in to their PC with a username and password which is not stored in the central Active Directory. When they access the TM1 Web with IE/Firefox they get a message: "Integrated login failed....Please try again.... System client server not found". When they click on OK they can now enter a username (the Active Directory name) and password (which is stored in the TM1 cube), but the message returns every time = they can't login.
If we remove the server name from "trusted sites" in the web browser they will not receive this message and they can login with the AD credentials. Unfortunately this is not a workable workaround because templates and export to Pdf/Excel will not properly work.
We get the same problem when we try to access TM1 Web from the TM1 server when we remove the credentials from the TM1 cube and try to login in as another user (which is available in AD/TM1 cube). This test should eliminate problems with firewalls etc...
What have we missed?
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Re: Integrated login failed
Post by Martin Erlmoser »
what happens if you make a copy of the tm1web folder, configure it as manual login and try it again?
users with ad account use tm1web
users w/o ad account use tm1web-manualloginwhatever
i can't follow you completely
what are you doing there?
do you call the tm1server tm1 cube, otherwise what has cube security to do with login stuff?
