Is it possible to create Admin rights for one cube only, for a specific user?
I tried creating a rule in the cell security cube, but didn't seem to work.
['User']=S:["Admin"]
How does one do this? I primarily want the user to be able to add members to a dimension.
Admin rights for one cube only for a specific user
- Version: 9.1
- Excel Version: Excel 2007
Re: Admin rights for one cube only for a specific user
You can allow the user to be able to do that if you create a TI process which they can run, whether from within Server Explorer or via an action button. Essentially, you allow the TI to do the addition by passing it the new elements as parameters.nickykolle wrote:Is it possible to create Admin rights for one cube only, for a specific user?
- LoadzaGrunt
- Version: LoadzaVersions
- Excel Version: LoadzaVersions
Right click on dimensions in Server Explorer and pick 'Security Assignments...'. You can then give a group 'Admin' privelege on a dimension. When users that are members of this group log in they should be able to 'Edit Dimension Structure' and add and remove elements. IIRC that user could also use XDI dimension worksheets.I primarily want the user to be able to add members to a dimension.
