Is there a way to show an attribute of the element next to the Element in the View.
For example,John claimed $60 travel expenses in June and Eric is John's Manager.
I would like to see
Name Manager June
John Eric 60.
Currently, I have been using DBRA to get the Manager's name after slicing the view.
Show Attributes next to element in View
Re: Show Attributes next to element in View
Short answer, no.telula wrote:Hello,
I would like to see
Name Manager June
John Eric 60.
Longer answer, you could do what you're looking for in a cube which had a dimension for the staff and another dimension for their manager, with the value written to the relevant combination of elements. Other than that your existing method is the one you'd need to go with.
- jim wood
- Version: PA 2.0.7
You could also do it in good old excel using the DBRA function. Alan's solution of using another cube to gather the information is however probably the better way to go.
- Steve Rowe
Or create an alias that was the element name and the attribute combined and just use that in your views.
That's good lateral thinkin'. the only issue will be that when you change an alias you may randomly get key error messages in slices until the server is rebooted, but I can't imagine managers changing on a regular basis.Steve Rowe wrote:Or create an alias that was the element name and the attribute combined and just use that in your views.
- jim wood
- Version: PA 2.0.7
Awake now. Apologies.jim wood wrote:You could also do it in good old excel using the DBRA function. Alan's solution of using another cube to gather the information is however probably the better way to go.
- wissew
- Version: 9.5.2; 10.2.2; 11
- Excel Version: 2003 SP3 - 2013
Another approach could be to have the management hierarchy layered in your employee dimension.
