When I try to create an application in the Contributor now there's a box asking user and pwd "IBM Cognos Client Framework". Never happened before.
I tried to reinstall the Rich Client, I checked de configs, I tried another browser, I checked the CogrcpServlet config, I deleted all Contributor applications in the server.
I tried all user/pwd, even the old ones and including my computer login. None works.
My sin was to try to setup Contributor for another TM1 Server...
I use Tomcat, TM1 9.5.
Thank you!
The cogrcp is as follows:
<?xml version="1.0" encoding="UTF-8"?>
<cogrcp>
<provisioning>
<updatesite>
<cookies>PMPSVC_SESSION=user~Admin|pgsize~15|sep~none|skin~ibm|view~list|cols~3|pLocale~en|cLocale~en|tz~default,JSESSIONID=016B6056B68AA9BB6B551EF5E3119AD3,PMPSVC_PASSPORT=37e8c889-aa72-46a9-becc-f6f3dd75407f,PMPSVC_SESSION=user~Admin|pgsize~15|sep~none|skin~ibm|view~list|cols~3|pLocale~en|cLocale~en|tz~default</cookies>
<url>http://IKEUCHI:8080/pmpsvc/rcp_updates</url>
</updatesite>
<application id="ModelingADT" version="8.4" />
<params>
</params>
</provisioning>
<appdata>
<params>
<param name="appdef">true</param>
<param name="pmpsvcAddress">http://IKEUCHI:8080/pmpsvc/services/PMPService</param>
<param name="pmpsvcPassport">37e8c889-aa72-46a9-becc-f6f3dd75407f</param>
<param name="pmpsvcPingMillis">900000</param>
<param name="nl">en</param>
<param name="nlContent">en</param>
<param name="webAddress">http://IKEUCHI:8080/pmpsvc</param>
</params>
</appdata>
</cogrcp>
Can't create Contributor Application
ravi
- OLAP Product: cognos
- Version: tm1 9.5
Re: Can't create Contributor Application
I think Cognos TM1 contributor component you would require 1. IBM WebSphere Application Server Community Edition (CE) V2.1.1.2 2. Apache Tomcat version 6.0.18
Ravi
Ravi
