ASCIIOutput or TextOutput without Line Feed/Carrige Return
ExApplix
OLAP Product: Cognos Tm1
Post by ExApplix »
I am using ASCIIOut to write to a text file. The file which I get looks like:
Record1
Record2
Record3
But my required outfile should NOT have any 'Line Feed' or 'Carrige Return' etc. and my output file should look like:
Record1Record2Record3.....
Is there a way in TM1 by which I can achieve that?
Please help!!
Re: ASCIIOutput or TextOutput without Line Feed/Carrige Retu
This seems like an odd requirement, why would you need to do this?
To your issue as stated:
You can alter the ASCIIOutput delimiter but not the line feed as far as I am aware.
There are two relatively easy workarounds I can think of.
1/ Keep the output text file as is and use vbscript or similar to read the records into a single line as required.
2/ CellPutS your items to a cube cell value on your data tab then just do a single ASCIIOutput on the Epilog
ExApplix
Post by ExApplix »
This is the requirement of the ERP system into which I want to load the data from the TM1 cubes. The text file should not have a line feed.
The text file will have thousands (could be millions) of rows of data (imported from the cube), so I think putting all the data into one single cell will not be possible.
Any ideas how can I do that?
I presume you will still need some kind of field delimiter? (Otherwise how does the ERP interpret a string of potentially millions of characters?)
If you're not talking just a few records but potentially a very large number then go with my 1st suggestion. Use some vb script to read through the output file and modify it by stripping out the line feed characters.
Shouldn't be to difficult.
olapuser
Version: 9.5
Post by olapuser »
ExApplix,
Simple TI can do that
# Prolog
DatasourceASCIIQuoteCharacter='';
DatasourceASCIIDelimiter='';
Record = '';
# Metadata
Record = Record | <Cube data / elements / something>;
# Data
# Epilog
ASCIIOutput('SAP.txt', Record);
olapuser wrote:ExApplix,
# Prolog
Record = '';
# Metadata
# Data
# Epilog
There are a few issues with that.
The first is that it was one of Lotsaram's initial suggestions. The second was ExApplix's statement that the file could run to potentially millions of rows of data. The third, and most crucial, is that there's an undocumented restriction in long strings post 9.4. My tests in 9.5 show that AsciiOutput will output a maximum of 7,999 characters. Beyond that, what you'll get is a message that the process has completed successfully and an empty text file. (Though it's probably undocumented because Iboglix couldn't conceive of someone outputting a string of that length.)
Lotsa's suggestion of using a post-generation script is really the only way to do this.
olapuser
Version: 9.5
Post by olapuser »
Alan,
You're right, this is odd.
Alan Kirk wrote:Lotsa's suggestion of using a post-generation script is really the only way to do this.
True.
Just use an easy VBS or VBA routine to convert the output generated by TI.
Shouldn't be so hard to do, it you'd want some assistance with it, I am happy to look at it.
You could have TI execute the code ;)
Wim
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
If you're accustomed to a C like language, you can use AWK for this. AWK is a very powerful and fast datastream processing language. I've used this in several projects for datafile pre- or postprocessing.
Michel
