ElementExist()
- Eric
- Version: 9.4
- Excel Version: 2003
ElementExist()
Is there a way to check if an element exist? I do not see it the help file, but I am sure it would exist. right?
Eric
Eric
- Mike Cowie
- OLAP Product: IBM TM1/PA, SSAS, and more
- Version: Anything thru 11.x
- Excel Version: 2003 - Office 365
Re: ElementExist()
Eric,
In Excel, Rules or Turbo Integrator, you can check if an element exists in a dimension using the DIMIX(DimensionName, ElementName) function. For element name, you can specify the actual element name or a valid alias. If the function returns a 0, the element doesn't exist; otherwise it returns the index of the element in the dimension.
Mike Cowie
QueBIT Consulting, LLC
- Eric
- Version: 9.4
Re: ElementExist()
FANTASTIC!
Eric
Eric
