We are a lengthy SQL statement in a Ti and it is taking quite some time to load the TI editor. Is there a switch on the cfg file that we can stop the query from running on opening? The reason being that we want to edit the code in the advanced tabs.
server is 64 bit
tm1 9.1 sp4
response time is same via client and server
Ti Response Time on SQL
- olap forum.zip
- (10.58 KiB) Downloaded 358 times
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Re: Ti Response Time on SQL
As far as I know there is no such a cfg parameter.camhale wrote:Hi,
One possible workaround:
If you change the ODBC definition on your PC to a wrong source then you get an error message about it soon after the double click on the process.
Then you can edit and save the TI process.
Do not forget to change the ODBC connection back at the end:) On the other hand TM1 will use the ODBC on the server side so you can leave it wrong at the developer PC.
Peter
Best Regards,
Peter
Peter
That's why they put the "F" in F.A.Q. (http://forums.olapforums.com/viewtopic.php?f=3&t=1332)camhale wrote:Hi,
server is 64 bit
tm1 9.1 sp4
Under "TurboIntegrator", see the heading "ODBC Data Source; Suppressing the Preview Display".
thanks
