Error message not seen before
LeeTaylor1979
OLAP Product: IBM Cognos TM1
Post by LeeTaylor1979 »
Has anyone come across the following message when trying to open a cube view as a client ?
View Title Element not defined
If so can you please tell me what the problem is ?
Lee
Re: Error message not seen before
Hi Lee,
This is probably because the title element of the view references a subset that is now empty, or a dimension to which you have no access to the elements of. If you can figure out which dimension and subset is and repopulate it then your view should start working.
Otherwise you will need to delete and rebuild the view.
Title elements are defined by index and not by name.
If the index value has been set at a value higher than the number of subset members that the user has access to then the error message you describe is what would be expected.
