please can anyone say me that,in which areas of TM1 issues will be raised,when migrating from 9.1 to 9.5,it is immediate requirement to finilaize time to completete the task for me.Please I just need ares only where can issues araise when migrating?
thanking you
Areas of issues.
Re: Areas of issues.
For only one area, the RAM memory used on the server will probably almost double since we're on Unicode since version 9.4.
The change to Unicode storage should only affect string data. It doesn't change the way numeric data (which will be most of it in most systems) is stored. Migrating from 32 bit to 64 bit would be a different story...Wim Gielis wrote:For only one area, the RAM memory used on the server will probably almost double since we're on Unicode since version 9.4.
(Were it otherwise, my humble 32 bit system probably couldn't even launch a 9.4 session.)
