Help with importing Date please
Christian
Version: 9.4
Post by Christian »
TM1 9.5
My date field in excel is in format *3/10/2010. My attribute in TM1 is mm/dd/yyyy. The sample in Turbo Integrator shows up as 2009-01-01 00:00:00.
When I run my process I get an error that it cannot convert to a real number. I have the variable for date set to numeric and data.
I searched the TI user guide, and searched Date on this site, but can't find anything on what I'm doing wrong.
Thanks!
Re: Help with importing Date please
Christian wrote:Hi All,
TM1 9.5
You can't import dates into TI as numeric values unless you convert them to serial dates, and even then Excel's serial dates (starting from 01-Jan-1900) are not the same as TI's (which start from 1960). TI has only two variable types; Numeric and String and if it's Numeric then it needs to be an actual number in "pure" number format.
Bring it in as a String data type instead, then parse the individual sections (day, month and year) then use the relevant Rules functions (like DayNo) to convert that to a date that TI can work with if you need to.
Christian
Version: 9.4
Post by Christian »
Thanks for the information Alan.
