I have a server up and running....integrated login in perspectives/architect works with the NTML security package. Works great. When I try to use integrated login through perspectives/architect using the Kerberos security, I receive a 'Server Principal name (SPN) or the security context of the destination server could not be established' error.
Why this matters. I'm upgrading TM1 versions and installing TM1 Web on a separate server. They need to use integrated login. NTML will only allow integrated login to TM1 web if Web and the service are on the same server.
Has anyone experienced this issue with Kerberos?
integrated login not working with Kerberos
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: integrated login not working with Kerberos
Are you running the TM1 server on a domain account? I think this is required when you use Kerberos.
Michel
Michel
Michael, thanks for the reponse. Yes TM1 is running under a domain account
- Michel Zijlema
