Did anyone manage to create alternative hierchies in Cognos 8 from a TM1 source? The only hierarchies I have seen were member hierarchies (consolidated elements), which unfortunately could not be combined on the oposite edges of a cross tab.
Thank you
Z
Alternative hierarchies in Cognos 8 from a TM1 source?
- Version: 9.5
Re: Alternative hierarchies in Cognos 8 from a TM1 source?
You can't use 2 hierarchies from the same dimension in the same reporting object (crosstab, list, etc.)
