Has anyone experianced the following - I am working on TM1 9.0 SP3 and on a couple of machines when your in a cube and drill to the subset editor each element is overlapping and doesnt look right. When you click ok everything closes down. You also cant select an element from a dimension while in the cube view.
Any ideas - Last week we had a virus and IT have made a number of changes to the virus checker settings and increased security - I am wondering if the this is linked.
Corrupt View
Re: Corrupt View
Is this the issue described in the FAQ Thread, under the heading "Subset Editor Displays Distorted Element Names (First two element names overlap)"?AWILDE wrote: Has anyone experianced the following - I am working on TM1 9.0 SP3 and on a couple of machines when your in a cube and drill to the subset editor each element is overlapping and doesnt look right. When you click ok everything closes down. You also cant select an element from a dimension while in the cube view.
AWILDE
- Version: 9.4
- Excel Version: 2003
Re: Corrupt View
Yes this has solved the problem - all I needed to do was resize the subset editor window then click cancel and the problem is solved.
Thanks a lot for the help.
