MDX with Expand Above in Subset
Posted: Tue Jan 22, 2019 7:11 pm
by kenship
I'm building a subset using MDX. The hierarchy structure looks like this:
Net Profit
> Gross Exp
> Exp Group
> GL Accounts
> Revenue
> Rev Group
> GL Accounts
The request is to list all of them to the lowest level but using Expand Above so that subtotal at the bottom, except Net Profit to remain on top.
When I use MDX and apply Expand Above, Net Profit will to the bottom, I use the Except statement to exclude it. But I have no luck putting Net Profit back to the top. No matter what MDX function I use to include Net Profit, it will show up at the bottom.
My question is: Is there any way to put Net Profit on top and keep the Expand Above layout.
Right now it looks like this, it won't show Net Profit at all.
EXCEPT(
{TM1DRILLDOWNMEMBER({[GL_Account].[NetProfit]},ALL,RECURSIVE)}
,{[GL_Account].[NetProfit]}
Thanks.
Kenneth
Re: MDX with Expand Above in Subset
Posted: Tue Jan 22, 2019 9:00 pm
by paulsimon
Hi Kenneth
The following should do it
{ UNION(
{ [GL_Account].[NetProfit]},
{ EXCEPT(
{ TM1DRILLDOWNMEMBER( { [GL_Account].[NetProfit] } , ALL , RECURSIVE ) } ,
The Union just puts Net Profit at the top, since you aren't expanding it, expand above won't apply. Not actually tried it, but it should work. Let me know.
Posted: Wed Jan 23, 2019 1:33 pm
by kenship
Thanks but unfortunately it still put Net Profit down at bottom.
I began to believe that since the elements expanded are coming from the same parent (Net Profit) that I want to place on top, the Expand Above overrides and put it at bottom no matter what the MDX said.
Kenneth
paulsimon wrote: ↑Tue Jan 22, 2019 9:00 pm
Hi Kenneth
{ UNION(
{ EXCEPT(
Posted: Wed Jan 23, 2019 10:00 pm
by paulsimon
Hi Kenneth
I see the problem. To get around it I did the following on the SDATA sample cubes, using the account2 dimension which is the most similar one I could find on a sample cube that we can both access.
The solution needs two subsets.
Create a Subset called Subset Exp Above, which has the Expand Above option and the MDX Expression
{ EXCEPT( {TM1DRILLDOWNMEMBER( {[account2].[Earnings Before Taxes] }, ALL, RECURSIVE )}, { [account2].[Earnings Before Taxes] }) }
I then created a second subset with the Expand Above option turned off and the Expression
{UNION( {[account2].[Earnings Before Taxes] } , {[account2].[Subset Exp Above] } ) }
The second part of the union references the subset created above. It appears that this gets around the problem. Even though the containing subset does not have Expand Above turned on, the Expand Above set on the Unioned in Subset is retained.
Posted: Thu Jan 24, 2019 7:51 am
by Wim Gielis
That's a good trick Paul !
Posted: Thu Jan 24, 2019 3:18 pm
by kenship
Agree! It's a good solution.
Thanks Paul!
Posted: Wed Oct 20, 2021 1:37 pm
I think it is worthwhile to resurect this post. I'm not sure in which version it was added to the server, and it remains undocumented, but there is now a dedicated TM1 specific MDX function to support expand above, TM1ToggleExpandMode
{TM1ToggleExpandMode( {<your set expression here>}, EXPAND_ABOVE)}
This is how expand above is supported in Workspace. The function is supported in 11.8 of the server (and maybe ealier?)
Posted: Wed Oct 20, 2021 2:24 pm
by MarenC
this didn't quite do what I expected.
I created the following MDX:
{TM1ToggleExpandMode( {TM1DRILLDOWNMEMBER( {[Brand].[UK and Europe]}, ALL, RECURSIVE )}, EXPAND_ABOVE)}
And the result was as follows:
I was expecting the following:
Maren
Posted: Wed Oct 20, 2021 7:27 pm
by Wim Gielis
Works fine for me, server version 11.8
{TM1ToggleExpandMode( {[Fct_Country].[Belgium]} + {[Fct_Country].[Total Country]}, EXPAND_ABOVE)}
Posted: Thu Oct 21, 2021 8:24 am
by MarenC
I am looking at version 11.9, get the same result in both PAW and Architect.
Not impressed by this new function so far!
Posted: Thu Oct 21, 2021 12:27 pm
by Wim Gielis
MarenC wrote: ↑Thu Oct 21, 2021 8:24 am
11.9 does not exist, does it ?
Posted: Thu Oct 21, 2021 3:01 pm
by MarenC
Hi Wim,
Actually I am on the following:
11.8.00800.5
I did a right click TM1sd.exe and details.
I blame looking at the CMPLST file for the previous false information!
Maren
Posted: Thu Oct 21, 2021 8:59 pm
by Wim Gielis
Thanks !
