Processing Error
Posted: Fri Mar 13, 2009 8:37 am
by jinia
I am getting the following status message while trying to process a cube in PROD.
"Finished building aggregations and indexes for measure group partition"
This screen is showing for 2days and the cube processing is not completing.
Can anybody help me in this topic.
Re: Processing Error
Posted: Fri Mar 13, 2009 9:14 am
by Alan Kirk
jinia wrote:I am getting the following status message while trying to process a cube in PROD.
Not in the OLAP Jobs forum, I think, unless you're looking to hire someone to sort it out for you?
Otherwise, it might be useful to indicate which OLAP tool you're using so that your message can be moved to the correct forum, and some users of that tool may be able to help you with an answer.
Posted: Fri Mar 13, 2009 10:13 am
by jinia
I am using Sql server 2005 Analysis Services.
Posted: Fri Mar 13, 2009 10:29 am
by Alan Kirk
OK, I've moved the topic from OLAP Jobs to MS Analysis Services. This post (incorporating your question) should e-mail out to anyone who's subscribed to that forum.
Posted: Thu Mar 19, 2009 6:09 am
by belair22
If it hasn't finished after 2 days I'd guess there's something not quite right.
Cancel processing and 'undo' the most recent change you made (if you can remember what it was). If that's no help I'd suggest revewing your SSAS 'processing options'.
