BAT & Perfmon
- Eric
- Version: 9.4
- Excel Version: 2003
BAT & Perfmon
Does anyone know if there is a way to use Batch files or CommandLine() to start performance monitoring (windows Run command perfmon)on the server, NOT TM1 Server with performance cubes. As always trying to see how many ways I can circumvent the IT department when executing new ETL's on Dev.
Eric
Eric
- Daniel Lennon
- Version: 9.1 SP2 Build 9.1.2.49
- Excel Version: 2003 2007
Re: BAT & Perfmon
Hi Eric,
You could always use VB in Excel...
Sub PerfMon()
Shell "perfmon", 1
End Sub
Kind Regards,
Daniel.
Sub PerfMon()
Shell "perfmon", 1
End Sub
Kind Regards,
Daniel.
- Daniel Lennon
Re: BAT & Perfmon
Kind Regards,Sub PerfMon()
Shell "perfmon", 1
End Sub
Daniel.
Re: BAT & Perfmon
cheers for that
Paolo
Paolo
- Eric
- Version: 9.4
Re: BAT & Perfmon
I used the command line to open an excel file that when it opens it runs the perfmon shell and then closes the excel file. Works perfect thanks!
Ok dumb question time.
How do I stop the perfmon in VBA?
Eric
Eric
- Steve Rowe
Re: BAT & Perfmon
A complete guess, did you try Shell "perfmon",0 ?
- Version: 2.5 to PA
- Excel Version: Lots
Re: BAT & Perfmon
Eric,
If you want to use the same Excel approach you can use:
Note: "Performance" is the title of the PerfMon window under XP, check that it is the same under your server OS, and %{F4} translates to Alt F4.
You need to be aware though, that if you have other foreground applications running on that server and one of those grabs the focus between the AppActivate and the SendKeys it will get the Alt F4 sent to it rather than to PerfMon.
Sub ClosePerfMon()
AppActivate "Performance"
SendKeys "%{F4}", True
End Sub
Andy Key
- Eric
- Version: 9.4
Re: BAT & Perfmon
Awesome!
Think I can use the same methodology to kill winzip after a backup? (If anyone doesn't know. If you call winzip via TI it will zip everythin, but it will not close after it is completed.
Eric
Eric
- Mike Cowie
- Version: Anything thru 11.x
Re: BAT & Perfmon
Just to add another command-line zipping utility to the list, I've had really good luck using 7ZIP, which is freeware:
http://www.7zip.com/
I haven't used it directly from TM1, but have done some extracting and zipping from other apps where a command-line EXE was needed.
Mike Cowie
QueBIT Consulting, LLC
