Xcelerator loading XLSM files to application folder
- Version: 9.0.0
- Excel Version: Excel 2007
I am tring to upload a macro enabled workbook to an application folder in Xcelerator, however it is addig an xlsx extension to the file making it unreadable in the process.
Does anyone know if there a setting in the .cfg that I need to be enabling.
Robert
Robert
- Version: 9.0.0
Re: Xcelerator loading XLSM files to application folder
I have done some further digging and a file Book4.xlsm which is uploaded to the application folder becomes in the }Externals\ Book4.xlsm.xlsx_20100917045222.xlsx
renaming the file has no affect as the .blob can't find the new file.
- LoadzaGrunt
- Version: LoadzaVersions
This definitely looks like a bug, not a feature...
You can do us all a favour and raise a ticket with IBM
- OLAP Product: Tm1
1. First you need to stop the Tm1 service (save your data first)
2. Create a blob file using text editor and place it under the appropriate applications folder (if any),
eg under }Applications\MyReports (or just }Applications if there are no sub folders)
- save the following as a file called say Book4.xlsm.blob
FILE_FORMAT=100
ENTRYNAME=Book4.xlsm
ENTRYTYPE=blob
ENTRYREFERENCE=TM1:///blob/public/.\}Externals\Book4.xlsm
3. Copy your file Book4.xlsm to }Externals - note Book4.xlsm has to be the same name as line 4 of the blob file.
4. Start the Tm1 service.
PS you don't need to upload the file via the Tm1 menus in Excel at any point. To update or modify the file going forward just open it directly from the }Externals folder and save.
FILE_FORMAT=100
ENTRYTYPE=blob
J.Rizk
Tm1 for everyone
Tm1 for everyone
- Version: 9.0.0
Thanks a lot for the help.
whilst the solution works, it's not great from a customer perspective so I will raise it with IBM as well as.
Robert
Robert
- Version: 2.0
- Excel Version: EXCEL 2013
I see that the last message was in October 2010 and we are in May 2011- Do we have a 'normal' solution for this problem.
I see the 'workaround', but I do not understand how to implement it.
Also, I have more than one xlsm to put in the applications.
Micheline
Micheline
It is my understanding that TM1 still only supports the adding of XLSX files to the application folder (for Excel 2007 and above). The only way to get it to work is going to be to do the workaround suggested by jrizk.mnasra wrote:I see that the last message was in October 2010 and we are in May 2011- Do we have a 'normal' solution for this problem.
- Version: 2.5 to PA
- Excel Version: Lots
Which part of the workaround are you having trouble with?
Andy Key
- Version: 2.0
What is a blob?
FILE_FORMAT=100
ENTRYTYPE=blob
Do I write exactly those 4 lines and I save the file as Book4.xlsm.blob
Do I have a book4.xlsm somewhere in my environment?
Where do I put the name of my own xlsm file? (and if I have 2?)
Sorry, on top of my english is not my first language, I am not a technical person.
What is a blob?
FILE_FORMAT=100
ENTRYTYPE=blob
Micheline
Micheline
mnasra wrote:2. Create a blob file using text editor and place it under the appropriate applications folder (if any),
What is a blob?
A blob file is just a plain text file with the extension .blob rather than .txt. You can create it with Notepad.
FILE_FORMAT=100
ENTRYTYPE=blob
Change every reference to Book4.xlsm to the name of the workbook that you want to add to your applications folders. Save the file as whatever you now have after ENTRYNAME= but with the .blob extension after .xlsm.
No, this is the workbook that you want to add.
The answer to the first question should be clear from the answers above. If you have more than one file to add, repeat the process.
Andy Key
I am having the same issue with xslx or xlsm files under Application folder. What is this }Application\ folder where this .blob file needs to be saved?
- Version: 2.0
THe }Application folder is under your SERVER name \datafiles\ }Application
I hope this helps
micheline
I hope this helps
micheline
Micheline
Micheline
- Martin Ryan
Anyone heard back from IBM on this issue? I've just encountered it two years and a few versions of TM1 later.
I'll work around by saving as .xls but I'd rather be able to save it in native Excel 2010 format as that's what's being used by all the users.
You can attach .xlsm's as shortcuts, as opposed to actually 'uploading' them thereby creating a copy in }Externals. Not sure if that's going to work for you Martin?
Robin Mackenzie
- Martin Ryan
Yeah, could probably make that work, thanks for the idea Robin.
