Hi Expert,
I am using an active form. I need to filtrate my first column with a value.
I created an MDX to do that and it works perfectly:
example:
{TM1FILTERBYPATTERN( {TM1DRILLDOWNMEMBER( {TM1SUBSETALL( [Classe] )}, ALL, RECURSIVE )}, '*am*')}
This will give me all the classes that contains AM
Now, I want the user to be able to enter am in a CELL (say $B$10).
How do I replace the '*am*' with the value in B10.
Thanks a million.
Micheline
PS: I tried the following as suggested in another chat, but it did not work
{TM1FILTERBYPATTERN( {TM1DRILLDOWNMEMBER( {TM1SUBSETALL( [Classe] )}, ALL, RECURSIVE )}, ' " &$B$10& " ' ) }
mdx replace value with excel coordinate
- Version: 2.0
- Excel Version: EXCEL 2013
Micheline
Micheline
- Version: 2.0
Re: mdx replace value with excel coordinate
Correction.
I tried
in a different environment (I think excel is newer) it worked.
Lesson learnt.
thanks
Micheline
I tried
Lesson learnt.
thanks
Micheline
Micheline
Micheline
- Version: 10.1.1
- Excel Version: Excel 2010
Just for info, I have moved away from using TM1FILTERBYPATTERN because it can't handle aliases.
The following topics describe the issues, and the workarounds using the INSTR function.
regards,
Mark
regards,
Mark
- Version: PAL 2.0.9.18
TM1FILTERBYPATTERN can handle aliases. Provide the alias name as a third argument within double quotes. I only found out last week and it seems this was new info to the community.
IBM Champion 2024
IBM Champion 2024
- Version: 10.1.1
Cheers Wim, I wasn't aware of the mystery 3rd parameter, and useful to know.
I should have read George Tonkin's MDX guide a bit more closely! That one went right over my head.
- gtonkin
3rd parameter is in my guide only because Wim found it!
